주요 콘텐츠로 건너뛰기
Nexus 7 2nd Generation Front Facing Camera Replacement
필요한 것
  1. Nexus 7 2nd Generation Front Facing Camera Replacement, Rear Panel: 1 단계, 이미지 1/1
    • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
    • Do not use excessive force while prying the clips. They can be easily broken.
  2. Nexus 7 2nd Generation Front Facing Camera Replacement: 2 단계, 이미지 1/2 Nexus 7 2nd Generation Front Facing Camera Replacement: 2 단계, 이미지 2/2
    • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
  3. Nexus 7 2nd Generation Front Facing Camera Replacement: 3 단계, 이미지 1/3 Nexus 7 2nd Generation Front Facing Camera Replacement: 3 단계, 이미지 2/3 Nexus 7 2nd Generation Front Facing Camera Replacement: 3 단계, 이미지 3/3
    • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
  4. Nexus 7 2nd Generation Front Facing Camera Replacement: 4 단계, 이미지 1/3 Nexus 7 2nd Generation Front Facing Camera Replacement: 4 단계, 이미지 2/3 Nexus 7 2nd Generation Front Facing Camera Replacement: 4 단계, 이미지 3/3
    • Pry up the rear panel along the left edge using the method described in previous steps.
  5. Nexus 7 2nd Generation Front Facing Camera Replacement: 5 단계, 이미지 1/2 Nexus 7 2nd Generation Front Facing Camera Replacement: 5 단계, 이미지 2/2
    • Gently lift and remove the rear panel up off the front panel assembly.
  6. Nexus 7 2nd Generation Front Facing Camera Replacement, Battery Cable: 6 단계, 이미지 1/2 Nexus 7 2nd Generation Front Facing Camera Replacement, Battery Cable: 6 단계, 이미지 2/2
    • Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
  7. Nexus 7 2nd Generation Front Facing Camera Replacement, Speaker Cable: 7 단계, 이미지 1/1
    • Peel back the copper ESD shielding covering the bottom of the motherboard.
    • Do not try to remove the copper shielding, as it is still attached underneath the battery.
    • If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
  8. Nexus 7 2nd Generation Front Facing Camera Replacement: 8 단계, 이미지 1/1
    • Using the tip of a spudger, push the speaker cable straight out of its socket on the motherboard.
  9. Nexus 7 2nd Generation Front Facing Camera Replacement, Power & Volume ZIF Connector: 9 단계, 이미지 1/1
    • Peel back the label covering the power and volume button ZIF connector.
  10. Nexus 7 2nd Generation Front Facing Camera Replacement: 10 단계, 이미지 1/2 Nexus 7 2nd Generation Front Facing Camera Replacement: 10 단계, 이미지 2/2
    • Use the tip of a spudger to carefully flip up the retaining flap on the power and volume button ribbon cable ZIF socket.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the power and volume button ribbon cable straight out of its socket.
  11. Nexus 7 2nd Generation Front Facing Camera Replacement, Motherboard Assembly: 11 단계, 이미지 1/2 Nexus 7 2nd Generation Front Facing Camera Replacement, Motherboard Assembly: 11 단계, 이미지 2/2
    • Carefully peel back the adhesive tape covering the I/O board ribbon cable socket on the motherboard.
  12. Nexus 7 2nd Generation Front Facing Camera Replacement: 12 단계, 이미지 1/2 Nexus 7 2nd Generation Front Facing Camera Replacement: 12 단계, 이미지 2/2
    • Use the tip of a spudger to carefully flip up the retaining flap on the I/O data ribbon cable ZIF socket.
    • Use the tip of a spudger to pull the I/O data ribbon cable straight out of its socket.
  13. Nexus 7 2nd Generation Front Facing Camera Replacement: 13 단계, 이미지 1/1
    • Peel back the adhesive tape covering the display and digitizer cable sockets.
    • It is not necessary to completely remove the adhesive, but it is helpful to fold it back on itself to get it out of the way.
  14. Nexus 7 2nd Generation Front Facing Camera Replacement: 14 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the display data cable straight up off its socket on the motherboard.
  15. Nexus 7 2nd Generation Front Facing Camera Replacement: 15 단계, 이미지 1/3 Nexus 7 2nd Generation Front Facing Camera Replacement: 15 단계, 이미지 2/3 Nexus 7 2nd Generation Front Facing Camera Replacement: 15 단계, 이미지 3/3
    • Use the flat end of a spudger to carefully flip up the retaining flaps on the digitizer ribbon cable ZIF sockets.
    • Make sure you are flipping up the retaining flaps, not the sockets themselves.
    • Use the tip of a spudger to pull the digitizer ribbon cable straight out of its socket.
  16. Nexus 7 2nd Generation Front Facing Camera Replacement: 16 단계, 이미지 1/2 Nexus 7 2nd Generation Front Facing Camera Replacement: 16 단계, 이미지 2/2
    • Use the tip of a spudger to remove the warranty seal stickers.
  17. Nexus 7 2nd Generation Front Facing Camera Replacement: 17 단계, 이미지 1/1
    • Remove the following screws securing the motherboard to the metal frame:
    • Six 3.25 mm silver Phillips screws
    • One 2.23 mm black Phillips screw
  18. Nexus 7 2nd Generation Front Facing Camera Replacement: 18 단계, 이미지 1/2 Nexus 7 2nd Generation Front Facing Camera Replacement: 18 단계, 이미지 2/2
    • Carefully lift the motherboard assembly out of the Nexus 7, minding any cables that may get caught.
  19. Nexus 7 2nd Generation Front Facing Camera Replacement, Motherboard: 19 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the front-facing camera straight off of its socket on the motherboard.
  20. Nexus 7 2nd Generation Front Facing Camera Replacement: 20 단계, 이미지 1/2 Nexus 7 2nd Generation Front Facing Camera Replacement: 20 단계, 이미지 2/2
    • Carefully pull the upper microphone straight up off its socket.
    • In a similar fashion, remove the rubber lower microphone gasket from the motherboard.
  21. Nexus 7 2nd Generation Front Facing Camera Replacement: 21 단계, 이미지 1/1
    • Motherboard remains.
  22. Nexus 7 2nd Generation Front Facing Camera Replacement, Front Facing Camera: 22 단계, 이미지 1/3 Nexus 7 2nd Generation Front Facing Camera Replacement, Front Facing Camera: 22 단계, 이미지 2/3 Nexus 7 2nd Generation Front Facing Camera Replacement, Front Facing Camera: 22 단계, 이미지 3/3
    • Flip the motherboard over to reveal the ZIF connectors for the two cameras.
    • The front facing camera will be the one on the left side. Start by prying the locking bar of the ZIF connector up with a spudger.
  23. Nexus 7 2nd Generation Front Facing Camera Replacement: 23 단계, 이미지 1/2 Nexus 7 2nd Generation Front Facing Camera Replacement: 23 단계, 이미지 2/2
    • Place the pointy end of the spudger underneath the cable ribbon to pull it from the connector.
    • Pry the camera off of the motherboard from the cable side and remove it from the motherboard.
    • You will likely damage the ribbon cable of the old camera when prying due to the strong adhesive used, but as long as you've got a replacement it shouldn't be a problem. You also may want to put a small drop of adhesive beneath the camera to affix it to the motherboard after installing it.
결론
Austin Blakely
회원 가입일: 03/11/19
19,389 평판
안내서 53개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 16,566개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 378
