주요 콘텐츠로 건너뛰기
Nexus 7 Black Screen Fix
  1. Nexus 7 Black Screen Fix, Nexus 7 Black Screen Fix: 1 단계, 이미지 1개 중 1개
    • Symptoms:
    • 1. Nexus 7 won't power on.
    • 2. Battery icon doesn't show when charger plugged in.
    • 3. In a dark room, you can see backlight is turned on. If you hold down power button for 30 seconds, you can see the backlight power cycle.
    • Solution:
    • 1. Hold down both volume buttons (Press the center) and plug in charger (while holding the buttons). Hold down for 40 seconds.
    • 2. Hold down power button 40 seconds to boot Nexus.
    • In the future, don't let battery discharge too much.
결론
This procedure has been used to fix 25 Nexus 7 tablets which were unopened for months and allowed to discharge too far.
다른 82명이 해당 안내서를 완성하였습니다.
Alan Nishioka
회원 가입일: 07/17/11
3,585 평판
안내서 8개를 작성함
54가이드 댓글
perfect! works like charm.
fireflysean - 답글
AH! I thought my Nexus was a goner and it's only about a month old! This worked immediately. Thanks for this fix.
thedomesticgeekblog - 답글
Great! Worked for me first time!
Ron Lopez - 답글
Complete failure. Nothing happened after performing those steps. Help me!!!!
Craig Walkup - 답글
Is the backlight cycling as described?
This worked for over 20 devices for me and recently I bought another one and it worked for this one too.
Alan Nishioka -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 35
지난 30일: 243
전체 시간: 77,154
