소개
Use this guide to replace the I/O Assembly cable (includes the headphone jack and micro-USB port).
Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
Peel back the copper ESD shielding covering the bottom of the motherboard.
If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
Remove the following screws securing the speaker assembly to the display assembly:
Two 4.25 mm black Phillips screws
One 3.2 mm silver Phillips screw
Use the tip of a spudger to peel back the cloth tape covering the headphone jack and the I/O assembly cable.
다른 144명이 해당 안내서를 완성하였습니다.
댓글 31개
This fix isn't too much of a pain if you can find the parts! The tape on the lower-left hand side was, oddly, a bit of a pain for me. Make sure you try to remove it from the left, and not from the right!
Got the cable and some recommended tools on Ebay for $30. Just did this on my old N7 and it works perfect now. Head up tho, the recommended tools didn't come with a small enough head for the two 2.3 mm black Phillips screws. Luckily i did have a super small one. Don't strip those or you SOL. Also the cable doesn't come with the headphone jack cover. it is held on with just tape so take that from the original cable.
Cable: http://www.ebay.com/itm/IO-PORT-CHARGER-...
Do a ebay search for "Nexus 7 I/O". Should pop up. Look for cheaper ones than the $60 ones.
Thank you so much for the clear guide. My Nexus 7 2012 is charging again! I ordered the part here: http://www.asusparts.eu/Asus-08301-00522...
