소개
Use this guide to replace the antenna board on your Nexus 9.
필요한 것
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Carefully peel up the copper shielding with your fingers.
Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
거의 끝나갑니다!
결론
