주요 콘텐츠로 건너뛰기
Nexus 9 Antenna Board Replacement
필요한 것
  1. Nexus 9 Antenna Board Replacement, Rear Case: 1 단계, 이미지 1/3 Nexus 9 Antenna Board Replacement, Rear Case: 1 단계, 이미지 2/3 Nexus 9 Antenna Board Replacement, Rear Case: 1 단계, 이미지 3/3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Antenna Board Replacement, Antenna Board: 2 단계, 이미지 1/2 Nexus 9 Antenna Board Replacement, Antenna Board: 2 단계, 이미지 2/2
    • This step is not necessary if you have already removed the battery.
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Antenna Board Replacement: 3 단계, 이미지 1/1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  4. Nexus 9 Antenna Board Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
결론
Geoff Wacker
회원 가입일: 09/30/13
90,038 평판
안내서 89개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 1,401
