소개
Use this guide to replace the front-facing camera on your Nexus 9.
필요한 것
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Use a spudger to disconnect the front-facing camera ZIF connector.
Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
