주요 콘텐츠로 건너뛰기
Nexus 9 Motherboard Replacement
필요한 것
  1. Nexus 9 Motherboard Replacement, Rear Case: 1 단계, 이미지 1/3 Nexus 9 Motherboard Replacement, Rear Case: 1 단계, 이미지 2/3 Nexus 9 Motherboard Replacement, Rear Case: 1 단계, 이미지 3/3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Motherboard Replacement, Front Facing Camera: 2 단계, 이미지 1/1
    • Use a spudger to disconnect the front-facing camera ZIF connector.
    • Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
  3. Nexus 9 Motherboard Replacement, Battery: 3 단계, 이미지 1/2 Nexus 9 Motherboard Replacement, Battery: 3 단계, 이미지 2/2
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  4. Nexus 9 Motherboard Replacement: 4 단계, 이미지 1/1
    • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
    • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
    • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
  5. Nexus 9 Motherboard Replacement: 5 단계, 이미지 1/1
    • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
    • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
  6. Nexus 9 Motherboard Replacement: 6 단계, 이미지 1/1
    • The battery should now lift free of the tablet.
  7. Nexus 9 Motherboard Replacement, Antenna Board: 7 단계, 이미지 1/2 Nexus 9 Motherboard Replacement, Antenna Board: 7 단계, 이미지 2/2
    • This step is not necessary if you have already removed the battery.
  8. Nexus 9 Motherboard Replacement: 8 단계, 이미지 1/1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  9. Nexus 9 Motherboard Replacement: 9 단계, 이미지 1/1
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
  10. Nexus 9 Motherboard Replacement, Motherboard: 10 단계, 이미지 1/2 Nexus 9 Motherboard Replacement, Motherboard: 10 단계, 이미지 2/2
    • Remove the three 3 mm T5 Torx screws.
    • Remove the five 2 mm Phillips #000 screws.
  11. Nexus 9 Motherboard Replacement: 11 단계, 이미지 1/2 Nexus 9 Motherboard Replacement: 11 단계, 이미지 2/2
    • Using your fingers, pull up on ribbon connector to expose another ribbon connector below.
    • Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
    • Pull up the ribbon connector with your fingers.
  12. Nexus 9 Motherboard Replacement: 12 단계, 이미지 1/1
    • Gently lift the motherboard up from the device.
  13. Nexus 9 Motherboard Replacement: 13 단계, 이미지 1/1
결론
다른 5명이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
89,935 평판
안내서 89개 작성하였습니다
댓글 2개
It is not necessary to remove the battery, just disconnect it. And you don't need to take all the copper off, just take it back to the battery.
Dakota Rickel - 답글
Hi all will you please help me where i can find the replacement motherboard for nexus 9 ?
My email is rinold83@gmail.com
Healthy & Yummy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 3,400
