주요 콘텐츠로 건너뛰기
Nexus 9 USB Daughterboard Replacement
필요한 것
  1. Nexus 9 USB Daughterboard Replacement, Rear Case: 1 단계, 이미지 1/3 Nexus 9 USB Daughterboard Replacement, Rear Case: 1 단계, 이미지 2/3 Nexus 9 USB Daughterboard Replacement, Rear Case: 1 단계, 이미지 3/3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 USB Daughterboard Replacement, Vibrator Daughterboard: 2 단계, 이미지 1/1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  3. Nexus 9 USB Daughterboard Replacement: 3 단계, 이미지 1/2 Nexus 9 USB Daughterboard Replacement: 3 단계, 이미지 2/2
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  4. Nexus 9 USB Daughterboard Replacement: 4 단계, 이미지 1/3 Nexus 9 USB Daughterboard Replacement: 4 단계, 이미지 2/3 Nexus 9 USB Daughterboard Replacement: 4 단계, 이미지 3/3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  5. Nexus 9 USB Daughterboard Replacement: 5 단계, 이미지 1/1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
  6. Nexus 9 USB Daughterboard Replacement, USB Daughterboard: 6 단계, 이미지 1/1
    • Remove the single 3mm T5 Torx screw.
    • Use a spudger to disconnect the display ribbon cable ZIF connector.
    • Gently lift the USB daughterboard up from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Geoff Wacker
회원 가입일: 09/30/13
89,934 평판
안내서 89개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 3,557
