주요 콘텐츠로 건너뛰기
Nexus One SIM Card Tray Replacement
필요한 것
  1. Nexus One SIM Card Tray Replacement, Rear Cover: 1 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement, Rear Cover: 1 단계, 이미지 2개 중 2개
    • Using two fingers, push up on the rear cover.
  2. Nexus One SIM Card Tray Replacement: 2 단계, 이미지 1개 중 1개
    • The rear cover slides up and off.
  3. Nexus One SIM Card Tray Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One SIM Card Tray Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the battery up and out.
  5. Nexus One SIM Card Tray Replacement, Battery Housing: 5 단계, 이미지 1개 중 1개
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One SIM Card Tray Replacement: 6 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement: 6 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One SIM Card Tray Replacement: 7 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement: 7 단계, 이미지 2개 중 2개
    • Pry the upper left tab open on the battery housing.
  8. Nexus One SIM Card Tray Replacement: 8 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement: 8 단계, 이미지 2개 중 2개
    • Pry the top tab of the battery housing.
  9. Nexus One SIM Card Tray Replacement: 9 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement: 9 단계, 이미지 2개 중 2개
    • Pry the right side tab of the battery housing.
  10. Nexus One SIM Card Tray Replacement: 10 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement: 10 단계, 이미지 2개 중 2개
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One SIM Card Tray Replacement, Lower Cover: 11 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement, Lower Cover: 11 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  12. Nexus One SIM Card Tray Replacement, Antenna Housing: 12 단계, 이미지 1개 중 1개
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
  13. Nexus One SIM Card Tray Replacement, Motherboards: 13 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement, Motherboards: 13 단계, 이미지 2개 중 2개
    • Insert the spudger under the connector.
    • Push the spudger up and twist to release the connector.
    • Repeat for the next connector.
  14. Nexus One SIM Card Tray Replacement: 14 단계, 이미지 3개 중 1개 Nexus One SIM Card Tray Replacement: 14 단계, 이미지 3개 중 2개 Nexus One SIM Card Tray Replacement: 14 단계, 이미지 3개 중 3개
    • Push on the USB port to expose the black connector.
    • Use the spudger to pry the connector upwards.
  15. Nexus One SIM Card Tray Replacement: 15 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement: 15 단계, 이미지 2개 중 2개
    • Place the spugder under the antenna connector.
    • Pry connector up vertically.
  16. Nexus One SIM Card Tray Replacement: 16 단계, 이미지 3개 중 1개 Nexus One SIM Card Tray Replacement: 16 단계, 이미지 3개 중 2개 Nexus One SIM Card Tray Replacement: 16 단계, 이미지 3개 중 3개
    • Insert the spudger into tab above the camera.
    • Slide upwards until the board detaches from the case.
  17. Nexus One SIM Card Tray Replacement: 17 단계, 이미지 1개 중 1개
    • Press the pointed tip of the spudger into the space below the button assembly.
    • Wiggle the spudger tip towards the outside of the button.
    • The button assembly is under some tension and may fly off.
  18. Nexus One SIM Card Tray Replacement: 18 단계, 이미지 1개 중 1개
    • Push the pointed tip of the spudger into the base of the side button board.
    • Lift up, the board will disconnect from the case.
  19. Nexus One SIM Card Tray Replacement: 19 단계, 이미지 3개 중 1개 Nexus One SIM Card Tray Replacement: 19 단계, 이미지 3개 중 2개 Nexus One SIM Card Tray Replacement: 19 단계, 이미지 3개 중 3개
    • Push on the lower motherboard until it slides under the case support.
    • The motherboard assembly comes out as a single piece.
    • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
  20. Nexus One SIM Card Tray Replacement, Upper Motherboard: 20 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement, Upper Motherboard: 20 단계, 이미지 2개 중 2개
    • Using the spudger, lift the blue colored connector.
    • Use the supdger to lift the black connetor up as well.
    • Detach the upper motherboard from the lower motherboard.
  21. Nexus One SIM Card Tray Replacement, SIM Card Tray: 21 단계, 이미지 1개 중 1개
    • Use the spudger to lift the SIM card tray connector off the motherboard.
  22. Nexus One SIM Card Tray Replacement: 22 단계, 이미지 2개 중 1개 Nexus One SIM Card Tray Replacement: 22 단계, 이미지 2개 중 2개
    • Use the spudger to lift the SIM tray board off the motherboard.
    • The SIM Tray hinges up, it is still connected by the copper tape.
    • add picture of SIM tray flipped over the side to complete guide.
결론
작성자
3다른 기여자 명과 함께
Niklas Johnson
회원 가입일: 01/31/12
1,207 평판
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 3,948
