주요 콘텐츠로 건너뛰기
Nexus One Secondary Microphone Replacement
필요한 것
  1. Nexus One Secondary Microphone Replacement, Rear Cover: 1 단계, 이미지 2개 중 1개 Nexus One Secondary Microphone Replacement, Rear Cover: 1 단계, 이미지 2개 중 2개
    • Using two fingers, push up on the rear cover.
  2. Nexus One Secondary Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • The rear cover slides up and off.
  3. Nexus One Secondary Microphone Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Secondary Microphone Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the battery up and out.
  5. Nexus One Secondary Microphone Replacement, Battery Housing: 5 단계, 이미지 1개 중 1개
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Secondary Microphone Replacement: 6 단계, 이미지 2개 중 1개 Nexus One Secondary Microphone Replacement: 6 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Secondary Microphone Replacement: 7 단계, 이미지 2개 중 1개 Nexus One Secondary Microphone Replacement: 7 단계, 이미지 2개 중 2개
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Secondary Microphone Replacement: 8 단계, 이미지 2개 중 1개 Nexus One Secondary Microphone Replacement: 8 단계, 이미지 2개 중 2개
    • Pry the top tab of the battery housing.
  9. Nexus One Secondary Microphone Replacement: 9 단계, 이미지 2개 중 1개 Nexus One Secondary Microphone Replacement: 9 단계, 이미지 2개 중 2개
    • Pry the right side tab of the battery housing.
  10. Nexus One Secondary Microphone Replacement: 10 단계, 이미지 2개 중 1개 Nexus One Secondary Microphone Replacement: 10 단계, 이미지 2개 중 2개
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Secondary Microphone Replacement, Secondary Microphone: 11 단계, 이미지 2개 중 1개 Nexus One Secondary Microphone Replacement, Secondary Microphone: 11 단계, 이미지 2개 중 2개
    • Using the spudger, pry upwards on the second microphone connector.
  12. Nexus One Secondary Microphone Replacement: 12 단계, 이미지 1개 중 1개
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
결론
작성자
3다른 기여자 명과 함께
Niklas Johnson
회원 가입일: 01/31/12
1,207 평판
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 2,333
