필요한 것
Using the plastic opening tool, push the blade into the space between the case and lower cover.
Turn the opening tool slightly, the lower cover will detach on that side.
Repeat on other side of the seam.
The lower cover will slide off.
Remove the one T5 Torx screw
Remove the one #00 Philips screw
Lift up the end of the antenna housing and slide it outwards.
Insert the spudger under the connector.
Push the spudger up and twist to release the connector.
Repeat for the next connector.
Using the spudger, lift the blue colored connector.
Use the supdger to lift the black connetor up as well.
Detach the upper motherboard from the lower motherboard.
다른 한 분이 해당 안내서를 완성하였습니다.
