주요 콘텐츠로 건너뛰기
Nexus Q Ball Bearing Ring Replacement
필요한 것
  1. Nexus Q Ball Bearing Ring Replacement, Ball Bearing Ring: 1 단계, 이미지 1/1
    • Squeeze and pull the cap to remove it from the Nexus Q.
  2. Nexus Q Ball Bearing Ring Replacement: 2 단계, 이미지 1/1
    • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
  3. Nexus Q Ball Bearing Ring Replacement: 3 단계, 이미지 1/1
    • Undo the ZIF connector by prying it with a spudger.
  4. Nexus Q Ball Bearing Ring Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
    • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
  5. Nexus Q Ball Bearing Ring Replacement: 5 단계, 이미지 1/1
    • View the bottom half of the Nexus Q.
    • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
  6. Nexus Q Ball Bearing Ring Replacement: 6 단계, 이미지 1/1
    • Remove the ball bearing ring.
    • When placing a new ring in its place, make sure to orient it right or the top will not close.
결론
Taewan Kim
회원 가입일: 01/31/13
22 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-10, Maness Winter 2013 Cal Poly, Team 7-10, Maness Winter 2013 회원
CPSU-MANESS-W13S7G10
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 12
전체 시간: 566
