주요 콘텐츠로 건너뛰기
Nexus Q LED Board Replacement
필요한 것
  1. Nexus Q LED Board Replacement, Ball Bearing Ring: 1 단계, 이미지 1개 중 1개
    • Squeeze and pull the cap to remove it from the Nexus Q.
  2. Nexus Q LED Board Replacement: 2 단계, 이미지 1개 중 1개
    • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
  3. Nexus Q LED Board Replacement: 3 단계, 이미지 1개 중 1개
    • Undo the ZIF connector by prying it with a spudger.
  4. Nexus Q LED Board Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
    • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
  5. Nexus Q LED Board Replacement: 5 단계, 이미지 1개 중 1개
    • View the bottom half of the Nexus Q.
    • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
  6. Nexus Q LED Board Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the ball bearing ring.
    • When placing a new ring in its place, make sure to orient it right or the top will not close.
  7. Nexus Q LED Board Replacement, LED Board: 7 단계, 이미지 2개 중 1개 Nexus Q LED Board Replacement, LED Board: 7 단계, 이미지 2개 중 2개
    • Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
    • Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
  8. Nexus Q LED Board Replacement: 8 단계, 이미지 2개 중 1개 Nexus Q LED Board Replacement: 8 단계, 이미지 2개 중 2개
    • With the diffuser out, we are exposed to the LED Board.
    • Use a spudger to lightly lift the LED board out.
결론
작성자
5다른 기여자 명과 함께
Taewan Kim
회원 가입일: 01/31/13
22 평판
안내서 2개를 작성함
Cal Poly, Team 7-10, Maness Winter 2013 Cal Poly, Team 7-10, Maness Winter 2013 회원
CPSU-MANESS-W13S7G10
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 589
