주요 콘텐츠로 건너뛰기
Nike+ Sportband Motherboard Replacement
필요한 것
  1. Nike+ Sportband Motherboard Replacement, External Case: 1 단계, 이미지 1/2 Nike+ Sportband Motherboard Replacement, External Case: 1 단계, 이미지 2/2
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Motherboard Replacement: 2 단계, 이미지 1/2 Nike+ Sportband Motherboard Replacement: 2 단계, 이미지 2/2
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Motherboard Replacement, Screen: 3 단계, 이미지 1/2 Nike+ Sportband Motherboard Replacement, Screen: 3 단계, 이미지 2/2
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Motherboard Replacement: 4 단계, 이미지 1/3 Nike+ Sportband Motherboard Replacement: 4 단계, 이미지 2/3 Nike+ Sportband Motherboard Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Motherboard Replacement: 5 단계, 이미지 1/2 Nike+ Sportband Motherboard Replacement: 5 단계, 이미지 2/2
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Motherboard Replacement: 6 단계, 이미지 1/3 Nike+ Sportband Motherboard Replacement: 6 단계, 이미지 2/3 Nike+ Sportband Motherboard Replacement: 6 단계, 이미지 3/3
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
  7. Nike+ Sportband Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • Remove the four highlighted screws from the motherboard using the Philips screwdriver.
  8. Nike+ Sportband Motherboard Replacement: 8 단계, 이미지 1/3 Nike+ Sportband Motherboard Replacement: 8 단계, 이미지 2/3 Nike+ Sportband Motherboard Replacement: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the metal tweezers to lift the motherboard out of the device.
결론
Alyssa Setnar
회원 가입일: 02/15/16
331 평판
안내서 3개 작성하였습니다
IUPUI, Team 9-9, Wilson Spring 2016 IUPUI, Team 9-9, Wilson Spring 2016 회원
IUPUI-WILSON-S16S9G9
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 265
