주요 콘텐츠로 건너뛰기
Nike+ Sportband Screen Replacement
필요한 것
  1. Nike+ Sportband Screen Replacement, External Case: 1 단계, 이미지 1/2 Nike+ Sportband Screen Replacement, External Case: 1 단계, 이미지 2/2
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Screen Replacement: 2 단계, 이미지 1/2 Nike+ Sportband Screen Replacement: 2 단계, 이미지 2/2
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Screen Replacement, Screen: 3 단계, 이미지 1/2 Nike+ Sportband Screen Replacement, Screen: 3 단계, 이미지 2/2
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Screen Replacement: 4 단계, 이미지 1/3 Nike+ Sportband Screen Replacement: 4 단계, 이미지 2/3 Nike+ Sportband Screen Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Screen Replacement: 5 단계, 이미지 1/2 Nike+ Sportband Screen Replacement: 5 단계, 이미지 2/2
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Screen Replacement: 6 단계, 이미지 1/3 Nike+ Sportband Screen Replacement: 6 단계, 이미지 2/3 Nike+ Sportband Screen Replacement: 6 단계, 이미지 3/3
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
결론
Daniel Burtner
회원 가입일: 02/15/16
101 평판
안내서 1개 작성함
IUPUI, Team 9-9, Wilson Spring 2016 IUPUI, Team 9-9, Wilson Spring 2016 회원
IUPUI-WILSON-S16S9G9
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 14
전체 시간: 254
