주요 콘텐츠로 건너뛰기
Nike SportWatch GPS Battery Replacement
필요한 것
  1. Nike SportWatch GPS Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Battery Replacement: 2 단계, 이미지 1/1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Battery Replacement: 3 단계, 이미지 1/1
    • Pry the black plastic piece above the battery out using a nylon or metal spudger.
    • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
  4. Nike SportWatch GPS Battery Replacement: 4 단계, 이미지 1/1
    • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
  5. Nike SportWatch GPS Battery Replacement: 5 단계, 이미지 1/1
    • The battery should then easily come out of the watch.
결론
To reassemble your device, follow these instructions in reverse order. Once reassembled, plug the watch back into a USB computer port to turn the watch back on and start the initial charge. Let charge to full capacity.
다른 9명이 해당 안내서를 완성하였습니다.
Ian Eichorn
회원 가입일: 10/22/15
678 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G8
3 회원들
안내서 5개 작성하였습니다
댓글 8개
Nice tutorial!
Do you know where I can buy the battery from?
Steeve H - 답글
Where can i buy a replacement battery?
Ricardo Henriques - 답글
Thank you for this guide and the link to the replacement battery.
The battery I received had an extra circuit board and the contacts/metal bands were thinner and further apart thus making direct replacement difficult, there was no way to create proper connection with the spring contacts using the black plastic pc . I ended up removing the extra PCB and soldered the battery with short leads directly to the spring contacts and this worked well.
Unfortunately, it seems the battery wasn't the only issue with the watch.. last night it was fully charged however by this morning it was almost totally empty.
amveszter - 답글
I bought mine from batteryspace.com. Great place for all battery types.
peezo83 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 34
전체 시간: 17,050
