주요 콘텐츠로 건너뛰기
Nike SportWatch GPS Front Panel Replacement
필요한 것
  1. Nike SportWatch GPS Front Panel Replacement, Front Panel: 1 단계, 이미지 1/1
    • Face the watch upside down so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws on the back using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Front Panel Replacement: 2 단계, 이미지 1/1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Front Panel Replacement: 3 단계, 이미지 1/1
    • Two size #000 2.5 mm long screws will appear at the top of the main board. Unscrew them using a size 000 Phillips head screwdriver.
  4. Nike SportWatch GPS Front Panel Replacement: 4 단계, 이미지 1/1
    • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and not removable.
  5. Nike SportWatch GPS Front Panel Replacement: 5 단계, 이미지 1/1
    • Use an iOpener that has been heated in the microwave for about a minute, or until warm. Place it on the front screen of the watch. Let it rest there for a minute.
    • If you are unfamiliar with this tool use the iOpener guide here
  6. Nike SportWatch GPS Front Panel Replacement: 6 단계, 이미지 1/1
    • Push the panel out from the back of the screen, using your fingers.
결론
Ian Eichorn
회원 가입일: 10/22/15
678 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G8
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Where I can find the replacement glass? regards
Erick Sobreiro - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 1,261
