주요 콘텐츠로 건너뛰기
Nike SportWatch GPS LCD Screen Replacement
필요한 것
  1. Nike SportWatch GPS LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • First, place the watch upside down so the back of the watch is exposed. Unscrew the six size #000 5 mm long screws located on the back panel using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS LCD Screen Replacement: 2 단계, 이미지 1/1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS LCD Screen Replacement: 3 단계, 이미지 1/1
    • Then, unscrew the two main board size #000 2.5 mm long screws using a size 000 Phillips head screwdriver.
  4. Nike SportWatch GPS LCD Screen Replacement: 4 단계, 이미지 1/1
    • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and is not removable.
  5. Nike SportWatch GPS LCD Screen Replacement: 5 단계, 이미지 1/1
    • Use the blue plastic removal tool once again to carefully remove the screen.
  6. Nike SportWatch GPS LCD Screen Replacement: 6 단계, 이미지 1/1
    • Pull the plastic piece that is highlighted in the picture out from the back of the screen.
  7. Nike SportWatch GPS LCD Screen Replacement: 7 단계, 이미지 1/1
    • For reassembly, make sure the highlighted area in the picture, goes over the black plastic piece that was removed in the previous step.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Zainab Hussein
회원 가입일: 10/27/15
222 평판
안내서 1개 작성함
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G8
3 회원들
안내서 5개 작성하였습니다
댓글 3개
Hello, I found your article very interesting, I was just wondering do you know where I can buy a replacement screen?
Thank you
Joseph Kermani - 답글
hello do you know where I can find a replacement screen ?
Thank you
SMOUN - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 3,450
