주요 콘텐츠로 건너뛰기
Nikon 1 AW 1 Motherboard Replacement
필요한 것
  1. Nikon 1 AW 1 Motherboard Replacement, Buttons: 1 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement, Buttons: 1 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement, Buttons: 1 단계, 이미지 3개 중 3개
    • Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
  2. Nikon 1 AW 1 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Using the Phillips PH00 screwdriver, remove the four 5.5mm screws in the red circles. Then use a plastic opening tool to pry off the tripod socket.
    • Remove the metal plate to have access to the 4.9mm screw under the orange circle, use the Phillips PH00 screwdriver to remove it.
  3. Nikon 1 AW 1 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Using a T4 head screwdriver remove the three 5.4mm screws marked with the red circles.
    • Use a 1/4" flathead screwdriver or a flat head tool to release the grip attachment screw.
    • Remove the camera strap eyelet.
  4. Nikon 1 AW 1 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the grip attachment screw.
    • Use a Phillips PH00 to remove the two 2.4mm screws on the grip attachment slot, then remove the slot.
  5. Nikon 1 AW 1 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Use a T4 screwdriver to remove the three 5.4mm screw marked with the red circles and the eyelet strap.
    • Use a plastic opening tool to lift the front camera cover off.
  6. Nikon 1 AW 1 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Use a Phillips PH00 to unscrew the two 3.5mm screws in red.
    • Press the flash pop-up button in the orange rectangle to be able to remove top cover of the camera.
  7. Nikon 1 AW 1 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to lift off the top panel.
  8. Nikon 1 AW 1 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • If you needed to replace any buttons, you may now do so by pulling them off.
  9. Nikon 1 AW 1 Motherboard Replacement, Internal Body Seal: 9 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement, Internal Body Seal: 9 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement, Internal Body Seal: 9 단계, 이미지 3개 중 3개
    • Use a Phillips PH00 screwdriver to remove the 3.8mm screw in red.
    • Use a Phillips PH00 screwdriver to remove the 4.9mm screw in orange.
    • Use a Torx T4 screwdriver to remove the four 5.5mm screws in yellow.
  10. Nikon 1 AW 1 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Separate rear panel from the camera main body, starting from the HDMI and USB connector side. Do NOT pull the rear panel completely off of the camera yet.
    • Use a plastic opening tool to pry out the connector marked in red.
  11. Nikon 1 AW 1 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pull out the old seal from the groove in the rear panel.
    • If you needed to replace the seal, you may now do so.
  12. Nikon 1 AW 1 Motherboard Replacement, Rear Panel: 12 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement, Rear Panel: 12 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement, Rear Panel: 12 단계, 이미지 3개 중 3개
    • Use a Phillips PH00 screwdriver to remove the seven 3.1mm screws marked in red.
    • Use a Phillips PH00 screwdriver to remove the two 3.6mm screws marked in orange.
    • Lift off the small plate as shown.
  13. Nikon 1 AW 1 Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Lift the rainbow cable to have access to the 3.1mm screw beneath it and unscrew it with a Phillips PH00 screwdriver.
    • Turn aside the LCD screen but do not completely remove it yet.
    • You will need to lift the sticky patch inside the the yellow rectangle, to access the 3.1mm screw marked in orange, remove it with Phillips PH00 screwdriver, then you will be able to separate the LCD screen from the rear panel.
  14. Nikon 1 AW 1 Motherboard Replacement: 14 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 14 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the back panel apart from LCD screen.
  15. Nikon 1 AW 1 Motherboard Replacement, Motherboard: 15 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement, Motherboard: 15 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement, Motherboard: 15 단계, 이미지 3개 중 3개
    • Use a Phillips PH00 screwdriver to remove the four 4.4mm screws marked in red.
    • You will need to lift the sticky patch to have access to the screws under it.
    • Use a Phillips PH00 screwdriver to remove the two 6.3mm screws marked in orange.
  16. Nikon 1 AW 1 Motherboard Replacement: 16 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 16 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 16 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Pull off the metal cover to gain access to the motherboard.
    • Remove the connectors first using precision tweezers. In total you will remove fifteen connectors wires.
    • Some connectors are under the sticky patch, be sure you remove all of them.
    • Use a Phillips PH00 screwdriver to remove the 4.3mm screw holding the motherboard to the main camera body.
  17. Nikon 1 AW 1 Motherboard Replacement: 17 단계, 이미지 3개 중 1개 Nikon 1 AW 1 Motherboard Replacement: 17 단계, 이미지 3개 중 2개 Nikon 1 AW 1 Motherboard Replacement: 17 단계, 이미지 3개 중 3개
    • Carefully remove the motherboard from the main camera body and replace it for a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Daniel Heshmaty
회원 가입일: 10/04/16
397 평판
안내서 3개를 작성함
USF Tampa, Team 3-4, Sullivan Fall 2016 USF Tampa, Team 3-4, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S3G4
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 915
