주요 콘텐츠로 건너뛰기
Nikon 1 J3 LCD Screen Replacement
필요한 것
  1. Nikon 1 J3 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2개 중 1개 Nikon 1 J3 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2개 중 2개
    • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
    • Remove the screws under the flaps covering the HDMI and mini USB ports.
  2. Nikon 1 J3 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully pry back the back plate.
    • The plastic of the back plate may crack.
  3. Nikon 1 J3 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
  4. Nikon 1 J3 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
결론
작성자
1다른 기여자 명과 함께
Austin Lackey
회원 가입일: 09/26/17
479 평판
안내서 4개를 작성함
USF Tampa, Team S11-G4, Passmore Fall 2017 USF Tampa, Team S11-G4, Passmore Fall 2017 회원
USFT-PASSMORE-F17S11G4
3 회원들
안내서 4개를 작성함
3가이드 댓글
Hey, I’m having trouble removing the back plate on step 2. It seems to be stuck on the side opposite the HDMI and USB ports, any tips for removing it? Thanks!
johnjames460 - 답글
Step 1 seems to mis removal of 2 screws. Check tutorial below:
https://www.lifepixel.com/tutorials/infr...
Marcel Rossewij - 답글
I am about to replace the lcd screen on my J4 - is the method the same as for the J3? And do I need any adhesive?
Nicholas Glover - 2nd April 2023
Nicholas Glover - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 1,471
