소개
This replacement may be necessary if all other options have been exhausted.
필요한 것
Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
Remove the screws under the flaps covering the HDMI and mini USB ports.
Use the plastic opening tool to pry off the connectors shown
Using your finger, pry off the connection flap.
다른 한 분이 해당 안내서를 완성하였습니다.
