주요 콘텐츠로 건너뛰기
Nikon COOLPIX P2 LCD Screen Replacement
필요한 것
  1. Nikon COOLPIX P2 LCD Screen Replacement, Case: 1 단계, 이미지 1/1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 LCD Screen Replacement: 5 단계, 이미지 1/3 Nikon COOLPIX P2 LCD Screen Replacement: 5 단계, 이미지 2/3 Nikon COOLPIX P2 LCD Screen Replacement: 5 단계, 이미지 3/3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 LCD Screen Replacement: 7 단계, 이미지 1/1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 LCD Screen Replacement: 8 단계, 이미지 1/2 Nikon COOLPIX P2 LCD Screen Replacement: 8 단계, 이미지 2/2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 1/2 Nikon COOLPIX P2 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 2/2
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 LCD Screen Replacement: 10 단계, 이미지 1/2 Nikon COOLPIX P2 LCD Screen Replacement: 10 단계, 이미지 2/2
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 LCD Screen Replacement: 11 단계, 이미지 1/1
결론
Joshua Avery
회원 가입일: 01/23/12
31 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-28, Amido Winter 2012 Cal Poly, Team 3-28, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G28
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,113
