주요 콘텐츠로 건너뛰기
Nikon COOLPIX P600 Battery Replacement
  1. Nikon COOLPIX P600 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the camera upside down so that the lens is facing away from you.
  2. Nikon COOLPIX P600 Battery Replacement: 2 단계, 이미지 1/2 Nikon COOLPIX P600 Battery Replacement: 2 단계, 이미지 2/2
    • Slide the switch on the battery cover towards the center of the camera.
  3. Nikon COOLPIX P600 Battery Replacement: 3 단계, 이미지 1/2 Nikon COOLPIX P600 Battery Replacement: 3 단계, 이미지 2/2
    • Once the battery cover is open, push the solid yellow tab in the direction of the arrow. This will then eject the battery out of the camera.
결론
To reassemble your device, follow these instructions in reverse order. Make sure the battery is pushed back into the battery compartment enough to have the yellow latch seen in step three click back over the top of the battery before attempting to close the battery cover.
첨부 문서
Geronimo Gutierrez IV
회원 가입일: 09/09/15
354 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team 1-5, Bruce Fall 2015 CSU Fullerton, Team 1-5, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G5
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 31
전체 시간: 2,175
