주요 콘텐츠로 건너뛰기
Nikon COOLPIX P600 Tripod Mount Replacement
필요한 것
  1. Nikon COOLPIX P600 Tripod Mount Replacement, Tripod Mount: 1 단계, 이미지 1/1
    • Position the back of the camera facing you and open the LCD screen to the left.
  2. Nikon COOLPIX P600 Tripod Mount Replacement: 2 단계, 이미지 1/2 Nikon COOLPIX P600 Tripod Mount Replacement: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to unscrew the two 5.556 mm screws under the LCD screen.
  3. Nikon COOLPIX P600 Tripod Mount Replacement: 3 단계, 이미지 1/3 Nikon COOLPIX P600 Tripod Mount Replacement: 3 단계, 이미지 2/3 Nikon COOLPIX P600 Tripod Mount Replacement: 3 단계, 이미지 3/3
    • Use a Phillips screwdriver and remove the eleven 5.556 mm screws around the outside frame of the camera.
  4. Nikon COOLPIX P600 Tripod Mount Replacement: 4 단계, 이미지 1/1
    • Open the "HDMI" rubber flap.
    • Use a Phillips screwdriver and remove the 5.556 mm screw underneath the flap.
  5. Nikon COOLPIX P600 Tripod Mount Replacement: 5 단계, 이미지 1/1
    • The flash button is located on the left side of the built-in flash compartment.
    • Press the flash button (as shown) to access flash.
  6. Nikon COOLPIX P600 Tripod Mount Replacement: 6 단계, 이미지 1/1
    • Use a spudger to wedge underneath the flash
    • Pry (up and down) to separate.
    • It is important to choose a tool that is ESD-safe to avoid accidental damage to the device. A black nylon spudger, or plastic opening tool, should be used whenever possible.
  7. Nikon COOLPIX P600 Tripod Mount Replacement: 7 단계, 이미지 1/1
    • Use your hands to gently pull the front and back of the camera apart.
    • Be careful not to damage the ribbon-wire shown in the red box.
  8. Nikon COOLPIX P600 Tripod Mount Replacement: 8 단계, 이미지 1/3 Nikon COOLPIX P600 Tripod Mount Replacement: 8 단계, 이미지 2/3 Nikon COOLPIX P600 Tripod Mount Replacement: 8 단계, 이미지 3/3
    • Use needle-nose tweezers to gently lift the black/grey latch towards the ribbon-wire (the latch rotates upward to release and snaps down to lock).
    • Be careful not to break the latch. It cannot be replaced.
    • Use tweezers to gently remove ribbon-wires.
    • Pull the ribbon-wires towards the back-end of the camera.
  9. Nikon COOLPIX P600 Tripod Mount Replacement: 9 단계, 이미지 1/1
    • Use a Phillips screwdriver and remove the single 6.350 mm screw, left of the mode-adjustment dial.
  10. Nikon COOLPIX P600 Tripod Mount Replacement: 10 단계, 이미지 1/2 Nikon COOLPIX P600 Tripod Mount Replacement: 10 단계, 이미지 2/2
    • Use needle-nose tweezers to remove the large ribbon-wire located under the screw.
    • Gently wiggle the ribbon out in an upward motion.
    • For easier access, you can push the black surface of the camera where the buttons and dials are located. Do not push too hard as this may break the plastic.
  11. Nikon COOLPIX P600 Tripod Mount Replacement: 11 단계, 이미지 1/2 Nikon COOLPIX P600 Tripod Mount Replacement: 11 단계, 이미지 2/2
    • Insert a plastic opening tool under the shutter button.
    • Gently pry (back and forth) between the rubber grip and camera casing.
  12. Nikon COOLPIX P600 Tripod Mount Replacement: 12 단계, 이미지 1/2 Nikon COOLPIX P600 Tripod Mount Replacement: 12 단계, 이미지 2/2
    • Place hands around the camera. Hold onto the mode dial and grip under the shutter button.
    • Gently push right thumb away and pull in left index finger to separate the camera halves.
  13. Nikon COOLPIX P600 Tripod Mount Replacement: 13 단계, 이미지 1/3 Nikon COOLPIX P600 Tripod Mount Replacement: 13 단계, 이미지 2/3 Nikon COOLPIX P600 Tripod Mount Replacement: 13 단계, 이미지 3/3
    • Use a Phillips screwdriver to remove the nine 3.175 mm screws on the inside of the camera.
    • Use tweezers to remove the golden bracket.
  14. Nikon COOLPIX P600 Tripod Mount Replacement: 14 단계, 이미지 1/1
    • Use tweezers to remove the white film under the shutter-release button.
    • This white film is a cover for the electrical components. The camera will not be affected if it rips or comes off completely.
    • Be careful: three high-discharge capacitor leads are located under this film, and can result in electric shock if touched.
  15. Nikon COOLPIX P600 Tripod Mount Replacement: 15 단계, 이미지 1/2 Nikon COOLPIX P600 Tripod Mount Replacement: 15 단계, 이미지 2/2
    • Use tweezers to remove the yellow ribbon-wire.
    • Gently wiggle it to the left and then out of its port.
  16. Nikon COOLPIX P600 Tripod Mount Replacement: 16 단계, 이미지 1/1
    • Use hands to remove the metal cover.
    • Pull the cover up.
  17. Nikon COOLPIX P600 Tripod Mount Replacement: 17 단계, 이미지 1/1
  18. Nikon COOLPIX P600 Tripod Mount Replacement: 18 단계, 이미지 1/2 Nikon COOLPIX P600 Tripod Mount Replacement: 18 단계, 이미지 2/2
    • The tripod connector is located at the bottom of the camera.
    • Use tweezers to remove the tripod connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Geronimo Gutierrez IV
회원 가입일: 09/09/15
354 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team 1-5, Bruce Fall 2015 CSU Fullerton, Team 1-5, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 23
전체 시간: 2,988
