주요 콘텐츠로 건너뛰기
Nikon COOLPIX P7700 Back Casing Replacement
필요한 것
  1. Nikon COOLPIX P7700 Back Casing Replacement, Back Casing: 1 단계, 이미지 1/2 Nikon COOLPIX P7700 Back Casing Replacement, Back Casing: 1 단계, 이미지 2/2
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Back Casing Replacement: 2 단계, 이미지 1/1
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Back Casing Replacement: 3 단계, 이미지 1/1
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Back Casing Replacement: 4 단계, 이미지 1/1
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Back Casing Replacement: 5 단계, 이미지 1/1
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Back Casing Replacement: 6 단계, 이미지 1/2 Nikon COOLPIX P7700 Back Casing Replacement: 6 단계, 이미지 2/2
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Back Casing Replacement: 7 단계, 이미지 1/1
    • Remove the back casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dustin Wahl
회원 가입일: 03/11/15
775 평판
안내서 4개 작성하였습니다
Colorado Springs, Team 2-7, Panko Spring 2015 Colorado Springs, Team 2-7, Panko Spring 2015 회원
UCCS-PANKO-S15S2G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 1,780
