주요 콘텐츠로 건너뛰기
Nikon COOLPIX P7700 Reflective Mirror Replacement
필요한 것
  1. Nikon COOLPIX P7700 Reflective Mirror Replacement, Back Casing: 1 단계, 이미지 1/2 Nikon COOLPIX P7700 Reflective Mirror Replacement, Back Casing: 1 단계, 이미지 2/2
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Reflective Mirror Replacement: 2 단계, 이미지 1/1
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Reflective Mirror Replacement: 3 단계, 이미지 1/1
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Reflective Mirror Replacement: 4 단계, 이미지 1/1
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Reflective Mirror Replacement: 5 단계, 이미지 1/1
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Reflective Mirror Replacement: 6 단계, 이미지 1/2 Nikon COOLPIX P7700 Reflective Mirror Replacement: 6 단계, 이미지 2/2
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Reflective Mirror Replacement: 7 단계, 이미지 1/1
    • Remove the back casing.
  8. Nikon COOLPIX P7700 Reflective Mirror Replacement, Reflective Mirror: 8 단계, 이미지 1/2 Nikon COOLPIX P7700 Reflective Mirror Replacement, Reflective Mirror: 8 단계, 이미지 2/2
    • Remove the three 4.3 mm screws on the right metal sheet using a Phillips #00 screwdriver.
  9. Nikon COOLPIX P7700 Reflective Mirror Replacement: 9 단계, 이미지 1/1
    • Lift the metal sheet up to locate the reflective mirror, but do not bend or remove it.
  10. Nikon COOLPIX P7700 Reflective Mirror Replacement: 10 단계, 이미지 1/1
    • Delicately remove the glass mirror and exchange it with the replacement mirror.
    • Place the metal sheet back down and secure the three 4.3 mm screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dustin Wahl
회원 가입일: 03/11/15
775 평판
안내서 4개 작성하였습니다
Colorado Springs, Team 2-7, Panko Spring 2015 Colorado Springs, Team 2-7, Panko Spring 2015 회원
UCCS-PANKO-S15S2G7
3 회원들
안내서 10개 작성하였습니다
댓글 2개
There is a further screw hidden under the black cover on the left hand side of the camera (visible in step 1).
Without removing this silver screw, it is not possible to take the camera apart.
There should be an explanation about how to properly remove the ribbon cable. One has to flick up a dark part attached to the ribbon cable socket (opposite to where the ribbon cable enters). Putting the cable back is not “easy”, it is rather fiddly. One needs to put down the dark part again, after inserting the cable.
The three screws for the silver backplate that presses the sensor against the spacers and lens need to be tighten just the right amount. One cannot just fully tighten them. These three screws determine the distance of the sensor to the lens and also its alignment to the lens. One essentially needs to perform a sensor calibration when putting the camera together again.
Finally, the part replaced in this guide is not a “reflective mirror”. It is probably a low pass filter, potentially an IR filter or both.
Tom C - 답글
And how can you calibrate, adjust?
lothar4460 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 13
전체 시간: 1,623
