주요 콘텐츠로 건너뛰기
Nikon COOLPIX S3600 Battery Cover Replacement
필요한 것
  1. Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: 1 단계, 이미지 2개 중 1개 Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: 1 단계, 이미지 2개 중 2개
    • Locate the battery cover on the right side of the bottom of the camera.
    • To open the cover, gently slide it in the direction indicated by the arrow.
  2. Nikon COOLPIX S3600 Battery Cover Replacement: 2 단계, 이미지 3개 중 1개 Nikon COOLPIX S3600 Battery Cover Replacement: 2 단계, 이미지 3개 중 2개 Nikon COOLPIX S3600 Battery Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Once the battery cover door is open, insert the pointed end of a spudger underneath the metal door hinge.
    • Gently twist the spudger; the battery door cover should pop off.
    • Completely remove the cover from the hinge.
결론
To reattach the battery cover door, align the metal hinge with the plastic cover and press the plastic cover downward until it snaps into place.
작성자
3다른 기여자 명과 함께
Kim Maxson
회원 가입일: 03/18/15
101 평판
안내서 1개를 작성함
Colorado Springs, Team 1-3, May Spring 2015 Colorado Springs, Team 1-3, May Spring 2015 회원
UCCS-MAY-S15S1G3
6 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 6
전체 시간: 445
