이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
Remove the 5x3mm screw holding down the panel on the side closest to the lens.
Remove the 3x2mm screw underneath the panel near the top of the camera.
Remove the 4x3mm on the opposite side near the selector wheel.
Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
Pry the back panel away from the body of the camera, using the space you just opened up.
A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
Remove the three 3x3mm screws that attach the front casing to the bottom.
Remove the two 3x2 screws and two 3.5x2.5 screws attaching the rear panel to the motherboard.
Detach the ribbon cable from the motherboard by flipping up the latch on the ribbon connector.
Unscrew the three 3x2mm screws that attach the cables to the front casing.
