주요 콘텐츠로 건너뛰기
Nikon CoolPix S5 Battery Replacement
필요한 것
  1. Nikon CoolPix S5 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • This will cause the SD/Battery cover to pop open.
  2. Nikon CoolPix S5 Battery Replacement: 2 단계, 이미지 1/1
    • Press orange clip to eject battery (battery not shown).
  3. Nikon CoolPix S5 Battery Replacement: 3 단계, 이미지 1/1
    • While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • This will cause the battery to fall into the hand (battery not shown).
  4. Nikon CoolPix S5 Battery Replacement: 4 단계, 이미지 1/1
    • Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
  5. Nikon CoolPix S5 Battery Replacement: 5 단계, 이미지 1/1
    • Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Patty Richeson
회원 가입일: 03/11/13
99 평판
안내서 4개 작성하였습니다
Clemson, Team 12-5, Benson Spring 2013 Clemson, Team 12-5, Benson Spring 2013 회원
CLEM-BENSON-S13S12G5
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 694
