주요 콘텐츠로 건너뛰기
Nikon CoolPix S5 Buttons Replacement
필요한 것
  1. Nikon CoolPix S5 Buttons Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the wristlet by untying the strap.
  2. Nikon CoolPix S5 Buttons Replacement: 2 단계, 이미지 1/1
    • Open the SD/Battery cover.
  3. Nikon CoolPix S5 Buttons Replacement: 3 단계, 이미지 1/2 Nikon CoolPix S5 Buttons Replacement: 3 단계, 이미지 2/2
    • Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
  4. Nikon CoolPix S5 Buttons Replacement: 4 단계, 이미지 1/2 Nikon CoolPix S5 Buttons Replacement: 4 단계, 이미지 2/2
    • Remove the side paneling of the camera by prying it off with your hands.
  5. Nikon CoolPix S5 Buttons Replacement: 5 단계, 이미지 1/2 Nikon CoolPix S5 Buttons Replacement: 5 단계, 이미지 2/2
    • Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
    • Repeat the removal of the two screws on the other side of the camera.
  6. Nikon CoolPix S5 Buttons Replacement: 6 단계, 이미지 1/2 Nikon CoolPix S5 Buttons Replacement: 6 단계, 이미지 2/2
    • Separate the back faceplate from the rest of the camera.
  7. Nikon CoolPix S5 Buttons Replacement, Buttons: 7 단계, 이미지 1/1
    • The plate holding the buttons is on the right side of the camera. Use your fingers to open it to the right, away from the LCD screen. Do not twist or force the panel open. It should lift easily.
  8. Nikon CoolPix S5 Buttons Replacement: 8 단계, 이미지 1/1
    • Pull on ribbon cables to disconnect ribbon cables.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Patty Richeson
회원 가입일: 03/11/13
99 평판
안내서 4개 작성하였습니다
Clemson, Team 12-5, Benson Spring 2013 Clemson, Team 12-5, Benson Spring 2013 회원
CLEM-BENSON-S13S12G5
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 472
