주요 콘텐츠로 건너뛰기
Nikon CoolPix S5 Plastic LCD Screen Cover Replacement
필요한 것
  1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the wristlet by untying the strap.
  2. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: 2 단계, 이미지 1/1
    • Open the SD/Battery cover.
  3. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: 3 단계, 이미지 1/2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: 3 단계, 이미지 2/2
    • Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
  4. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: 4 단계, 이미지 1/2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: 4 단계, 이미지 2/2
    • Remove the side paneling of the camera by prying it off with your hands.
  5. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: 5 단계, 이미지 1/2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: 5 단계, 이미지 2/2
    • Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
    • Repeat the removal of the two screws on the other side of the camera.
  6. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: 6 단계, 이미지 1/2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: 6 단계, 이미지 2/2
    • Separate the back faceplate from the rest of the camera.
  7. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: 7 단계, 이미지 1/2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: 7 단계, 이미지 2/2
    • Press lightly on the outer surface of the plastic LCD screen cover in each corner.
    • The plastic LCD screen cover should pop out of the back plate.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Josh Miller
회원 가입일: 03/11/13
87 평판
안내서 3개 작성하였습니다
Clemson, Team 12-5, Benson Spring 2013 Clemson, Team 12-5, Benson Spring 2013 회원
CLEM-BENSON-S13S12G5
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 421
