주요 콘텐츠로 건너뛰기
Nikon CoolPix S5 Wrist Strap Holder Replacement
필요한 것
  1. Nikon CoolPix S5 Wrist Strap Holder Replacement, Wrist Strap Holder: 1 단계, 이미지 1/1
    • Remove the wrist strap from the wrist strap holder by untying the string at the end of the wrist strap.
    • This will allow for the wrist strap to be pulled through the wrist strap holder.
  2. Nikon CoolPix S5 Wrist Strap Holder Replacement: 2 단계, 이미지 1/1
    • Using the thumb, firmly push the Battery/SD cover in the middle and in the direction of the arrow on the Battery/SD cover.
    • This will cause the Battery/SD cover to pop open.
  3. Nikon CoolPix S5 Wrist Strap Holder Replacement: 3 단계, 이미지 1/1
    • Use the Phillips screwdriver to remove the four screws on the bottom of the camera.
  4. Nikon CoolPix S5 Wrist Strap Holder Replacement: 4 단계, 이미지 1/1
    • Using fingers, pull the silver side panels from each side.
  5. Nikon CoolPix S5 Wrist Strap Holder Replacement: 5 단계, 이미지 1/1
    • On the right hand side of the camera, remove the two screws from the wrist strap handle by using the Phillips screwdriver.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Patty Richeson
회원 가입일: 03/11/13
99 평판
안내서 4개 작성하였습니다
Clemson, Team 12-5, Benson Spring 2013 Clemson, Team 12-5, Benson Spring 2013 회원
CLEM-BENSON-S13S12G5
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 570
