주요 콘텐츠로 건너뛰기
Nikon CoolPix S600 Front and Rear Casing Replacement
필요한 것
  1. Nikon CoolPix S600 Front and Rear Casing Replacement, Front and Rear Casing: 1 단계, 이미지 1/1
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 Front and Rear Casing Replacement: 2 단계, 이미지 1/1
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 Front and Rear Casing Replacement: 3 단계, 이미지 1/1
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 Front and Rear Casing Replacement: 4 단계, 이미지 1/2 Nikon CoolPix S600 Front and Rear Casing Replacement: 4 단계, 이미지 2/2
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 Front and Rear Casing Replacement: 5 단계, 이미지 1/2 Nikon CoolPix S600 Front and Rear Casing Replacement: 5 단계, 이미지 2/2
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 Front and Rear Casing Replacement: 6 단계, 이미지 1/1
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 Front and Rear Casing Replacement: 7 단계, 이미지 1/1
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 Front and Rear Casing Replacement: 8 단계, 이미지 1/2 Nikon CoolPix S600 Front and Rear Casing Replacement: 8 단계, 이미지 2/2
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 Front and Rear Casing Replacement: 9 단계, 이미지 1/1
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 Front and Rear Casing Replacement: 10 단계, 이미지 1/3 Nikon CoolPix S600 Front and Rear Casing Replacement: 10 단계, 이미지 2/3 Nikon CoolPix S600 Front and Rear Casing Replacement: 10 단계, 이미지 3/3
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
결론
andreas anggasastra
회원 가입일: 09/14/11
116 평판
안내서 5개 작성하였습니다
Cuesta, Team 1-6, Zipperian Fall 2011 Cuesta, Team 1-6, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G6
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,251
