부품
부품은 필요하지 않습니다.
  1. With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Remove the chrome side cover from the body of the camera.
    • Remove the chrome side cover from the body of the camera.
  3. Remove the four 3.2 mm screws on the bottom of the camera.
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward) Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Gently separate the back cover from the body of the camera. The back casing will still be connected to the circuit board by a ribbon
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Use the tweezers to disconnect the ribbon from the circuit board.
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  8. Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  9. Gently separate the front cover from the body of the camera. The front casing will still be connected to the circuit board by a few wires
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  10. Remove the two 3.2 mm screws that hold the flash to the front cover.
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  11. Use the Spudger to remove the copper colored light bulb clip. Remove the front cover entierly from the camera body. Remove the front cover entierly from the camera body.
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  12. From the top view of the camera, remove the one 5.8 mm screw. From the top view of the camera, remove the one 2.8 mm screw
    • From the top view of the camera, remove the one 5.8 mm screw.
    • From the top view of the camera, remove the one 2.8 mm screw
  13. Remove the three 3.4 mm screws from the back side of the camera.
    • Remove the three 3.4 mm screws from the back side of the camera.
  14. Remove the two 3.4 mm screws from the side of the camera.
    • Remove the two 3.4 mm screws from the side of the camera.
  15. Separate the two metal body pieces from the rest of the camera.
    • Separate the two metal body pieces from the rest of the camera.
  16. Gently remove the two ribbons connecting the lens to the mother board. Gently remove the two ribbons connecting the lens to the mother board.
    • Gently remove the two ribbons connecting the lens to the mother board.
  17. Gently separate the camera lens from the mother board. Gently separate the camera lens from the mother board.
    • Gently separate the camera lens from the mother board.
  18. The mother board is permanently fixed to the battery housing.
    • The mother board is permanently fixed to the battery housing.
    • Mother board cannot be taken a part any further.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
andreas anggasastra
회원 가입일: 2011년 09월 14일
116 평판
안내서 5개 작성하였습니다
Cuesta, Team 1-6, Zipperian Fall 2011 Cuesta, Team 1-6, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G6
2 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 1
전체 시간: 1,110
