이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replacing the LCD screen of a Nikon Coolpix 3500.
필요한 것
Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
Remove the battery.
Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
Remove the two 4.5 mm screws that sit next to the battery slot.
Remove the 3 mm screw that sits below the CF card slot.
Remove the 4.5 mm screw that sits above the digital I/O cover.
Detach the grey-capped wire found near the edge of the board.
Located next to the blue wires is a green chip. Detach that green chip.
Remove the 2.5 mm screw.
Remove the two 3.4 mm screws.
Remove the two 4.4 mm screws.
