주요 콘텐츠로 건너뛰기
Nikon Coolpix 3500 Lens Replacement
필요한 것
  1. Nikon Coolpix 3500 Lens Replacement, Battery: 1 단계, 이미지 1/1
    • Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
    • Remove the battery.
    • Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
  2. Nikon Coolpix 3500 Lens Replacement, Front Cover: 2 단계, 이미지 1/1
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
  3. Nikon Coolpix 3500 Lens Replacement: 3 단계, 이미지 1/1
    • Remove the two 4.5 mm screws that sit inside the battery slot.
  4. Nikon Coolpix 3500 Lens Replacement: 4 단계, 이미지 1/1
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
  5. Nikon Coolpix 3500 Lens Replacement: 5 단계, 이미지 1/1
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  6. Nikon Coolpix 3500 Lens Replacement: 6 단계, 이미지 1/2 Nikon Coolpix 3500 Lens Replacement: 6 단계, 이미지 2/2
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the motherboard.
  7. Nikon Coolpix 3500 Lens Replacement: 7 단계, 이미지 1/2 Nikon Coolpix 3500 Lens Replacement: 7 단계, 이미지 2/2
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
  8. Nikon Coolpix 3500 Lens Replacement, Lens: 8 단계, 이미지 1/1
    • Disconnect the grey-capped wire from the motherboard.
    • Disconnect the blue wire attached to the green chip from the center of the motherboard.
  9. Nikon Coolpix 3500 Lens Replacement: 9 단계, 이미지 1/2 Nikon Coolpix 3500 Lens Replacement: 9 단계, 이미지 2/2
    • Remove the 3.5 mm screw from the motherboard next to the rotating lens.
    • Invert the motherboard and lens toward the orange and blue wires still connecting the motherboard to the LED screen.
  10. Nikon Coolpix 3500 Lens Replacement: 10 단계, 이미지 1/2 Nikon Coolpix 3500 Lens Replacement: 10 단계, 이미지 2/2
    • Disconnect the blue wire connecting the motherboard to the LED screen.
    • Disconnect the orange wire using a spudger while pushing out horizontally.
    • Disconnect the red capped wire from the motherboard.
    • Lift the motherboard and lens (still connected) out of the back case.
  11. Nikon Coolpix 3500 Lens Replacement: 11 단계, 이미지 1/1
    • Lift up on the black covering and remove the orange wire connecting the lens to the motherboard.
결론
richard guenther
회원 가입일: 04/19/10
183 평판
안내서 6개 작성하였습니다
Cal Poly, Team 30-38, Garner Spring 2010 Cal Poly, Team 30-38, Garner Spring 2010 회원
CPSU-GARNER-S10S30G38
5 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 3,024
