소개
The Nikon Coolpix 3500 is a beautiful camera for easily taking 16-megapixel photos and Full HD videos, even in difficult lighting. This camera can have occasional issues, one of which includes the camera not turning on. If your Nikon Coolpix 3500 is not turning on and you have tried charging it, or even replacing the battery, then the motherboard may be your issue. Please visit Nikon Coolpix 3500 Battery Replacement for more information on battery replacement.
The motherboard is commonly known as the “main board”. It is the part of many devices that essentially connects all the different bits of the device in one big circuit.
This repair could be challenging for beginners. It is recommended to have some assistance from someone with experience with motherboards. Detaching the wiring is the most involved task in this repair, but iFixit believes in you. If you are struggling with this repair, or finding that the instructions are not clear, iFixit encourages you to reach out to our Answers Forum.
필요한 것
Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
Remove the battery.
Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
Remove the two 4.5 mm screws that sit next to the battery slot.
Remove the 3 mm screw that sits below the CF card slot.
Remove the 4.5 mm screw that sits above the digital I/O cover.
Detach the grey-capped wire found near the edge of the board.
Located next to the blue wires is a green chip. Detach that green chip.
