필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove two 4.5 mm screws next to the battery slot.
Remove one 3 mm screw above the CF memory card slot.
Remove one 4.5 mm screw next to the CF memory card slot.
Remove the five 3.5 mm screws from the bottom of the camera.
Gently pry off the grey faceplate.
Use a spudger to disconnect the white-capped wire at the bottom of the camera.
Use a spudger to disconnect the orange-capped wire at the bottom of the camera and set the faceplate aside.
Disconnect the grey-capped wires from the motherboard.
Disconnect the blue wire attached to the green chip from the center of the motherboard.
Remove the 3.5 mm screw from the motherboard next to the rotating lens.
Flip the motherboard and lens over to access the three wires on the back that connect to the LED screen.
Disconnect the blue wire connecting the motherboard to the LED screen.
Disconnect the orange wire using a spudger while pushing out horizontally.
Disconnect the red capped wire from the motherboard.
Lift the motherboard and lens (still connected) out of the back case.
Lift up on the black covering and remove the orange wire connecting the lens to the motherboard.
Remove the 2.5 mm screw next to the red capped wire.
Remove the two 3.4 mm screws on the back of the directional buttons.
Remove the two 4.4 mm screws in the metal plate across from the orange wire.
Gently lift the LED screen out of the remaining casing and set it aside.
