주요 콘텐츠로 건너뛰기
Nikon Coolpix 4100 LCD screen Replacement
필요한 것
  1. Nikon Coolpix 4100 LCD screen Replacement, Opening the Case: 1 단계, 이미지 1/1
    • Tool on left - PH000 screwdriver
    • Tool on right - iPod fix-it tool
    • Soldering Iron
  2. Nikon Coolpix 4100 LCD screen Replacement: 2 단계, 이미지 1/1
    • Locate the 3 black screws on the bottom of the camera and the 2 gray screws on each side of the camera. Remove them with a PH000 screwdriver.
  3. Nikon Coolpix 4100 LCD screen Replacement: 3 단계, 이미지 1/2 Nikon Coolpix 4100 LCD screen Replacement: 3 단계, 이미지 2/2
    • Locate the gray band that you removed the screws from; this holds the two halves of the camera together. Use an iPod fix-it tool to pry the gray band loose and remove it.
  4. Nikon Coolpix 4100 LCD screen Replacement: 4 단계, 이미지 1/1
    • Use the iPod fix-it tool to separate the back panel from the camera.
  5. Nikon Coolpix 4100 LCD screen Replacement, LCD screen: 5 단계, 이미지 1/1
    • Use the iPod fix-it tool to carefully pry the screen from the logic board.
    • There's a ribbon cable that connects the screen to the logic board.
  6. Nikon Coolpix 4100 LCD screen Replacement: 6 단계, 이미지 1/1
    • This view shows the ribbon cable that connects to the screen.
  7. Nikon Coolpix 4100 LCD screen Replacement: 7 단계, 이미지 1/1
    • Flip the screen down. To disconnect the ribbon cable from the logic board, rock each end of the brown metal retainer that holds the ribbon cable in place until the ribbon disconnects.
  8. Nikon Coolpix 4100 LCD screen Replacement: 8 단계, 이미지 1/1
    • Remove the two screws on the top edge of the circuit board to the right of the viewfinder.
  9. Nikon Coolpix 4100 LCD screen Replacement: 9 단계, 이미지 1/1
    • To connect the new screen, solder the wires in place and connect the ribbon cable to the logic board.
  10. Nikon Coolpix 4100 LCD screen Replacement: 10 단계, 이미지 1/1
    • Unthread the four wires running across the top of the viewfinder from the plastic brackets holding them in place.
  11. Nikon Coolpix 4100 LCD screen Replacement: 11 단계, 이미지 1/1
    • Remove the two black screws threaded vertically into the top of the viewfinder. Loosen the flash and circuit board for more accessibility. This will allow for the viewfinder to be replaced.
결론
Travis Buck
회원 가입일: 09/25/12
107 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-2, Buehl Fall 2012 Ohio State, Team 1-2, Buehl Fall 2012 회원
OSU-BUEHL-F12S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 1,156
