소개
This installation guide will help you remove and replace the flash assembly for the Nikon Coolpix 4600 camera. The lens assembly is very intricate and complicated, disassembly of the actual lens assembly should only be attempted by a professional. This guide will demonstrate how to remove and replace the assembly as a whole unit.
필요한 것
Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
Using a Phillips 00 screwdriver, remove all of the six screws.
Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
After disconnecting the data ribbon, you can now separate the back case from the front case.
Locate and remove the four 4.25 mm screws on the motherboard using a Phillips 00 screw driver.
The flash and lens assembly should now be separate from the motherboard.
Locate the capacitor. It is the component that looks similar in size and shape to a AAA battery.
With the lens upright and facing you, gently lift the capacitor up and to the left to remove main flash assembly.
