주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon Coolpix 5400 Battery Replacement
필요한 것
  1. Nikon Coolpix 5400 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the camera so that the base is oriented facing up and the front of the camera is facing towards you.
  2. Nikon Coolpix 5400 Battery Replacement: 2 단계, 이미지 2개 중 1개 Nikon Coolpix 5400 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Push the battery compartment door latch, located on the right-hand side of the camera, away from you to release the catch.
    • Release the latch and pull your hand away. The spring inside the compartment will push both the battery up and the door open.
    • Push the battery door the rest of the way open to fully expose the battery.
  3. Nikon Coolpix 5400 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Grasp the battery with your thumb and forefinger and pull up and out of the camera housing.
결론
작성자
2다른 기여자 명과 함께
Savanah Cosand
회원 가입일: 04/04/19
303 평판
안내서 2개를 작성함
2가이드 댓글
I want to buy charger
MdYasir# - 답글 공유
I have a changer but it is not working.please help me to charge it
MdYasir# - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 64
전체 시간: 863
