주요 콘텐츠로 건너뛰기
Nikon Coolpix 775 Motherboard Replacement
필요한 것
  1. Nikon Coolpix 775 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Nikon Coolpix 775 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Nikon Coolpix 775 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the camera, so the bottom is facing up.
  2. Nikon Coolpix 775 Motherboard Replacement: 2 단계, 이미지 1/2 Nikon Coolpix 775 Motherboard Replacement: 2 단계, 이미지 2/2
    • Slide the gray latch to the open "pac-man" symbol.
  3. Nikon Coolpix 775 Motherboard Replacement: 3 단계, 이미지 1/3 Nikon Coolpix 775 Motherboard Replacement: 3 단계, 이미지 2/3 Nikon Coolpix 775 Motherboard Replacement: 3 단계, 이미지 3/3
    • Flip up the cover and remove the battery inside the slot.
  4. Nikon Coolpix 775 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/3 Nikon Coolpix 775 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/3 Nikon Coolpix 775 Motherboard Replacement, Motherboard: 4 단계, 이미지 3/3
    • Unscrew the eight 4mm long JIS #00 screws from the bottom, right side, and the left side.
  5. Nikon Coolpix 775 Motherboard Replacement: 5 단계, 이미지 1/3 Nikon Coolpix 775 Motherboard Replacement: 5 단계, 이미지 2/3 Nikon Coolpix 775 Motherboard Replacement: 5 단계, 이미지 3/3
    • Grab the camera with both your hand from the front and the back.
    • Pull the two parts apart.
    • You may have to pull at different angles to get the two parts to separate, but make sure you don't pull too hard because there is a wire connection on the inside.
  6. Nikon Coolpix 775 Motherboard Replacement: 6 단계, 이미지 1/3 Nikon Coolpix 775 Motherboard Replacement: 6 단계, 이미지 2/3 Nikon Coolpix 775 Motherboard Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Flip the camera back so you can see the top.
    • Pull the ribbon cable out of the socket connecting to the motherboard by using your hands or tweezers.
    • Be careful not to puncture or rip the ribbon cable.
  7. Nikon Coolpix 775 Motherboard Replacement: 7 단계, 이미지 1/3 Nikon Coolpix 775 Motherboard Replacement: 7 단계, 이미지 2/3 Nikon Coolpix 775 Motherboard Replacement: 7 단계, 이미지 3/3
    • Look back to the top of the camera.
    • Flip up the tab that is exposed right by the dial using tweezers.
    • Release the ribbon to be able to separate the top part of the back of the camera.
    • Be careful not to rip the ribbon cable.
  8. Nikon Coolpix 775 Motherboard Replacement: 8 단계, 이미지 1/3 Nikon Coolpix 775 Motherboard Replacement: 8 단계, 이미지 2/3 Nikon Coolpix 775 Motherboard Replacement: 8 단계, 이미지 3/3
    • Look at the top side of the camera.
    • Unscrew the two 4mm Phillips #00 screws.
    • Unscrew the 2mm JIS #00 screw as well.
  9. Nikon Coolpix 775 Motherboard Replacement: 9 단계, 이미지 1/3 Nikon Coolpix 775 Motherboard Replacement: 9 단계, 이미지 2/3 Nikon Coolpix 775 Motherboard Replacement: 9 단계, 이미지 3/3
    • Push or slide the the top dial toward the backside of the camera to unclip from the motherboard.
  10. Nikon Coolpix 775 Motherboard Replacement: 10 단계, 이미지 1/2 Nikon Coolpix 775 Motherboard Replacement: 10 단계, 이미지 2/2
    • Pull the red and black wire out of the socket on the motherboard.
    • Pull motherboard up out of camera.
  11. Nikon Coolpix 775 Motherboard Replacement: 11 단계, 이미지 1/3 Nikon Coolpix 775 Motherboard Replacement: 11 단계, 이미지 2/3 Nikon Coolpix 775 Motherboard Replacement: 11 단계, 이미지 3/3
    • Pull the ribbon connected to the dial off the motherboard.
결론
Suketu Patel
회원 가입일: 11/05/18
303 평판
안내서 2개 작성하였습니다
IUPUI, Team S2-G3, Baechle Fall 2018 IUPUI, Team S2-G3, Baechle Fall 2018 회원
IUPUI-BAECHLE-F18S2G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 11
전체 시간: 252
