메인 콘텐츠로 스킵하기
소개
Use this guide to replace the back cover.
  1. Remove the four 3.0mm screws on the bottom of the camera.
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove the two 3.0mm screws on the right side of the camera.
    • Remove the two 3.0mm screws on the right side of the camera.
  5. Carefully open the back cover. Take care as there are connectors still attached.
    • Carefully open the back cover. Take care as there are connectors still attached.
  6. Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  7. Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
결론
Kaky Payne
회원 가입일: 2012년 04월 17일
58 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-38, Regan Spring 2012 Cal Poly, Team 12-38, Regan Spring 2012 회원
CPSU-REGAN-S12S12G38
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 955
