이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
Carefully open the back cover. Take care as there are connectors still attached.
Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
Carefully flip the screen down to reveal the back of the screen
Disconnect the ribbon cable and gray connector with red and black wires.
Depending on your spare part, you may now need to carefully pry the screen back cover off. It is held by a double sided sticky tape on the inside. Be gentle!
