주요 콘텐츠로 건너뛰기
Nikon Coolpix 995 LCD Replacement
필요한 것
  1. Nikon Coolpix 995 LCD Replacement, LCD: 1 단계, 이미지 1/2 Nikon Coolpix 995 LCD Replacement, LCD: 1 단계, 이미지 2/2
    • Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
    • Remove the two screws with a Phillips #00 screwdriver.
    • Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
    • Refer to the second image to locate the second set of screws. The relevant screws are highlighted in red.
  2. Nikon Coolpix 995 LCD Replacement: 2 단계, 이미지 1/1
    • Flip the camera up-side down.
    • Remove the two Phillips #00 screws located near the battery compartment.
  3. Nikon Coolpix 995 LCD Replacement: 3 단계, 이미지 1/1
    • Open the memory card compartment cover.
    • You can now see four screws under the cover. Remove all four screws.
    • Refer to the image to locate the four screws. Make sure that you remove only the four screws identified in the image.
  4. Nikon Coolpix 995 LCD Replacement: 4 단계, 이미지 1/2 Nikon Coolpix 995 LCD Replacement: 4 단계, 이미지 2/2
    • Use your thumb to carefully lift the bottom side of the casing near the battery.
    • Pay attention to a cable located at the top of the assembly, as it is prone to breakage. Refer to the second image to locate the cable.
  5. Nikon Coolpix 995 LCD Replacement: 5 단계, 이미지 1/1
    • Use a spudger to flip the tabs that hold the screen.
    • Refer to the image for more details. The tabs are circled in red.
  6. Nikon Coolpix 995 LCD Replacement: 6 단계, 이미지 1/1
    • Carefully lift the LCD from the bottom. It should come out fairly easily.
결론
Cory Layman
회원 가입일: 10/04/11
89 평판
안내서 3개 작성하였습니다
UW Stout, Team 1-5, Zhou Fall 2011 UW Stout, Team 1-5, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G5
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 16
전체 시간: 2,288
