주요 콘텐츠로 건너뛰기
Nikon Coolpix 995 Memory Card Replacement
  1. Nikon Coolpix 995 Memory Card Replacement, Memory Card: 1 단계, 이미지 1/2 Nikon Coolpix 995 Memory Card Replacement, Memory Card: 1 단계, 이미지 2/2
    • Set camera so the memory card compartment is facing you.
    • Place thumb under cover latch where it says "card", then gently lift straight upwards.
  2. Nikon Coolpix 995 Memory Card Replacement: 2 단계, 이미지 1/1
    • -Pull the memory card with your thumb gently .
  3. Nikon Coolpix 995 Memory Card Replacement: 3 단계, 이미지 1/2 Nikon Coolpix 995 Memory Card Replacement: 3 단계, 이미지 2/2
    • Be sure your memory card is facing the right direction, then gently insert it into the memory card slot.
    • After you properly reinsert the memory card, place your thumb on the top of the cover and gently press down until you hear and feel the cover click back into the closed position.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cory Layman
회원 가입일: 10/04/11
89 평판
안내서 3개 작성하였습니다
UW Stout, Team 1-5, Zhou Fall 2011 UW Stout, Team 1-5, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G5
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 2,268
