주요 콘텐츠로 건너뛰기
Nikon Coolpix A900 Rear Case Replacement
필요한 것
  1. Nikon Coolpix A900 Rear Case Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. Nikon Coolpix A900 Rear Case Replacement: 2 단계, 이미지 1/2 Nikon Coolpix A900 Rear Case Replacement: 2 단계, 이미지 2/2
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
  3. Nikon Coolpix A900 Rear Case Replacement: 3 단계, 이미지 1/2 Nikon Coolpix A900 Rear Case Replacement: 3 단계, 이미지 2/2
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. Nikon Coolpix A900 Rear Case Replacement, Rear Case: 4 단계, 이미지 1/3 Nikon Coolpix A900 Rear Case Replacement, Rear Case: 4 단계, 이미지 2/3 Nikon Coolpix A900 Rear Case Replacement, Rear Case: 4 단계, 이미지 3/3
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. Nikon Coolpix A900 Rear Case Replacement: 5 단계, 이미지 1/3 Nikon Coolpix A900 Rear Case Replacement: 5 단계, 이미지 2/3 Nikon Coolpix A900 Rear Case Replacement: 5 단계, 이미지 3/3
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. Nikon Coolpix A900 Rear Case Replacement: 6 단계, 이미지 1/3 Nikon Coolpix A900 Rear Case Replacement: 6 단계, 이미지 2/3 Nikon Coolpix A900 Rear Case Replacement: 6 단계, 이미지 3/3
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
  7. Nikon Coolpix A900 Rear Case Replacement: 7 단계, 이미지 1/2 Nikon Coolpix A900 Rear Case Replacement: 7 단계, 이미지 2/2
    • Remove the two black 2.5 mm screws from the monitor bracket.
  8. Nikon Coolpix A900 Rear Case Replacement: 8 단계, 이미지 1/2 Nikon Coolpix A900 Rear Case Replacement: 8 단계, 이미지 2/2
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. Nikon Coolpix A900 Rear Case Replacement: 9 단계, 이미지 1/3 Nikon Coolpix A900 Rear Case Replacement: 9 단계, 이미지 2/3 Nikon Coolpix A900 Rear Case Replacement: 9 단계, 이미지 3/3
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
결론
Andres Aronstam
회원 가입일: 09/17/19
735 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 395
