주요 콘텐츠로 건너뛰기
Nikon Coolpix AW130 Battery Door Replacement
필요한 것
  1. Nikon Coolpix AW130 Battery Door Replacement, Battery: 1 단계, 이미지 1/2 Nikon Coolpix AW130 Battery Door Replacement, Battery: 1 단계, 이미지 2/2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Door Replacement: 2 단계, 이미지 1/2 Nikon Coolpix AW130 Battery Door Replacement: 2 단계, 이미지 2/2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Door Replacement: 3 단계, 이미지 1/1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Battery Door Replacement: 4 단계, 이미지 1/2 Nikon Coolpix AW130 Battery Door Replacement: 4 단계, 이미지 2/2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Battery Door Replacement, Battery Door: 5 단계, 이미지 1/2 Nikon Coolpix AW130 Battery Door Replacement, Battery Door: 5 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws on the underside of the camera.
  6. Nikon Coolpix AW130 Battery Door Replacement: 6 단계, 이미지 1/1
    • Using the metal spudger, carefully pry on the plastic plate.
    • The plastic plate should begin to loosen. Completely remove it from the camera body.
  7. Nikon Coolpix AW130 Battery Door Replacement: 7 단계, 이미지 1/2 Nikon Coolpix AW130 Battery Door Replacement: 7 단계, 이미지 2/2
    • Open the battery door. Near the hinge, a pair of screws should now be exposed.
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws.
  8. Nikon Coolpix AW130 Battery Door Replacement: 8 단계, 이미지 1/1
    • Pull the battery door away from the camera body.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lauren Stepp
회원 가입일: 01/29/16
1,251 평판
안내서 8개 작성하였습니다
댓글 6개
Where can I purchase the battery cover?
Thanh Tran - 답글
Where can I buy the AW130 battery door?
Jose - 답글
I’m trying to replace the battery door. I removed the 2 bottom screws and loosened the plate as in Steps 5 and 6. How do I remove the plate without breaking it?
Jose - 답글
like jose I have removed the screws and loosened the plate but can’t figure out how to remove it. How do I get it out?
Marianne Chaffin Strickland - 답글
Need web site to order battery door?
Connie Mossor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 27
전체 시간: 4,116
