소개
Safely replacing the battery door is a necessary step in protecting the internal components of the camera. Thoroughly completing this process also protects the waterproof integrity of the piece.
필요한 것
Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
Push the yellow battery/charger compartment tab up using your thumb nail.
This yellow tab spring broken, how I can repair
From where I can get this yellow tab, and how I can replace
Using a Phillips #00 screwdriver, remove the 2, 4mm screws on the underside of the camera.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 6개
Where can I purchase the battery cover?
Thanh Tran - 답글
like jose I have removed the screws and loosened the plate but can’t figure out how to remove it. How do I get it out?
Need web site to order battery door?
The spring that holds the yellow tab over the battery is apparently broken/loose on my camera, and was wondering if there is a solution without replacing the camera or using an external battery charger?
