주요 콘텐츠로 건너뛰기
Nikon Coolpix AW130 Battery Replacement
  1. Nikon Coolpix AW130 Battery Replacement, Battery: 1 단계, 이미지 1/2 Nikon Coolpix AW130 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Replacement: 2 단계, 이미지 1/2 Nikon Coolpix AW130 Battery Replacement: 2 단계, 이미지 2/2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Replacement: 3 단계, 이미지 1/1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Battery Replacement: 4 단계, 이미지 1/2 Nikon Coolpix AW130 Battery Replacement: 4 단계, 이미지 2/2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
결론
Lauren Stepp
회원 가입일: 01/29/16
1,251 평판
안내서 8개 작성하였습니다
댓글 한 개
Try the following before ordering your battery :
The problem with my cool pix aw130 was the little yellow plastic tab ( seen in one of the above photos ; step 3 ) that supposed to keep the battery shoved tightly against the terminals . In time , it wears and the battery no longer makes contact ; hence never getting recharged . The fix is simple ! Cut a 1/4” x 1/4” piece of paper , cardboard , or plastic , and wedge it between the yellow tab and the battery . Then recharge , as before .
Franklin Noel Stein - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 25
전체 시간: 2,369
